hi frnds, i am facing a error in Nav R2 report while running i.e “Dimension array should be identical”. but same report is running successfully in different database(by exporting the report object).
Any customization ???
yes sir…
Check array for dimension
SIR I HAVE CHECKED ARRAY DIMENSIONS OF ALL VARIABLES.
SIR IS THERE SOME OTHER PLACE WHERE SHOULD I CHK THE DIMENSION EXCEPT GOLBALS VARIABLE PROPERTY.
Please dont post same question multiple times…
You can check in each functions Local variables also…
