Dimension printing in report
I Have four dimension Department,Cost center,Purpose,Project.In my case i need to print the only one dimension in report(Department).I am using display method.I have tried this in report but its printing both dimension.how do i achieve the same?
Thanks in advance.
Saju.K
try this - i haven’t tested this…
str s;
s = Dimensions::find(SysDimension::Department,Dimension[1]).Description;/////dimension is the variable for Dimension
Thank you kranthi…
Is it working? because i have not tested it…
hi,
I have not tested it.In last development only i had this problem.there I have changed the width.It was working fine.So same thing came to my mind now.so i have posted now.i have noted this .i will test it.
Saju.K
