Dimension not selected error
We just upgraded from 2.6 to 3.7. We are getting the above error sporadically when we post gl journals even though the dimension is entered. The user reselects the dimensions and it posts fine. This mainly happens with recurring journals the 1st time it is run after the upgrade. It also occurs in regular journals. Has anyone else run into similar errors after the upgrade?
