As Harish said, go to Inventory > Setup > Parameters. here in number sequence tab, see whether the edt you have created for number sequence is displaying. There, you need to set the number sequenc “pkv” to that edt and save . also you need to check the continious loop option. If u dont check it, same number only be printed and you wont get5 new number sequence
