Dimension- Financial
Hi Friends,
How to setup default dimension while doing journal entry. My question
is if i will do any entry System will automatically take Dimension.
it will not ask me " enter dimension"
Ravi
Can set the same on GL, Item, Customer, Vendor, sites, Fixed Asset or banks.
It will flow from all these master in GL entry.
where to set?? where I have to go for setting this option.
you require to create financial dimension first in General Ledger.
Then in all the master mentioned above you will get financial dimension.
