Dimension Error on PO
Hi, When we try to post a purchase order that contains lines of items in Microsoft Business Solutions - Navision 4.0 SP1, the purchase order is not posted. We receive the following error message: Select a Dimension Value Code for the Dimension Code dimension for Item #####(Item No) There is a dimension is selected for that particular line item and the Value Posting box is set to Code Mandatory on the item card. In addition, this item has been received therefore we can not delete it. Does any one have any ideas? We never had this problem with other purchase orders. Thanks,
Hi Are you sure you are looking at the line dimensions and not the order dimensions? If you are in a test environment remove the code mandatory and see if it then posts, then see what it posts with. You could also try re-entering the line and seeing if this makes any difference. Anything forcing dimension entry on the ledger accounts?
Steve, Although the message point to that particular item, the problem was on Item charge. As soon as I assigned a dimension on Item charge line, the order posted. Thanks,
