Dimension Code in Firm Plannned Prod. Order
I have problem. This problem means i want shot Dimension Code in Order Planning.
when I enter the dimensions “manually” in the order planning and then click make orders, the dimensions get copied to the production order header and lines (that is default and I have no problem with it), however it doesn’t get copy to the Prod. Order components and that is my problem that I would like to solve.
What version of Nav are you running on?
Follow the link below for a similar problem and solution for Version 4.0
http://dynamicsuser.net/forums/t/5775.aspx
Hope this helps
HI DaveT,
I use NAV5.SP1. but thank you i 'll to see.
