I have a scenario, the dimension doesn’t copy to the Delivery challan lines. This stops the generation of
Delivery Challan. My setup for Dimension code is “Same Code” and is defined on the item card.
Case. is related to Subcontracting Indian localisation. I have set the dimension “Value posting” as same code in the Item card.
When we send the components to subcontractor, system is asking to select the dimension
for the component item.
What could be the issue and Solution?
Pl. clarify the above point.
thanks in advance.
