1 . What is the difference between " edit field and display field "?
2 . What is the difference between " validate and validate write " ?
please reply asap
please reply asap
display fields for display - you cannot edit it…
validate method is for a field - and it will validate the entered field value …
The validate method in the form and validateField method in the tables works as same…
Where as validate write method will validate - may be one or more field values before committing the transaction…
Thank you Kranthi
Can you please tell me “how many delete actions are used in AX?”
I think you need to go through the Development documentation given by Microsoft …
