Difference in opening balance from one server to other in ax 2012
There is a difference in accounts opening balance between two different servers like AOS1, AOS2 If we db syn or restart AOS the issue is getting fixed temporarily but again this issue raises what is the permanent solution for this, any one please suggest a solution.
Thanks in advance,
Where you are looking at the opening balance? In Trail balance or any report?
