Difference between two dates in X++ specific format.
Dear all,
I want to find difference between two dates in specific format
For example:
Date 01 - 15/04/1990.
Date 02 - 01/04/2014.
Output like. 23 years 11 months 15 days.
Can any tell me. how to get this.
thanks in advance.
Can you check if this would help you.
static void NumberofMonthsbetweenTwodates(Args _args)
date inputDate = str2Date(“1/1/2000”, 213);
date refDate = str2Date(“3/4/2009”, 213);
int noOfMonths,noOfMonthsBetweenYears,noOfDays;
noOfMonths = intvNo(refDate, inputDate, intvScale::Month);
noOfMonthsBetweenYears = intvNo(refDate, inputDate, intvScale::Year);
noOfDays = intvNo(refDate, inputDate, intvScale::Day);
info(“noOfMonths :”+int2str(noOfMonths) + " ,NoOfYears :"+int2str(noOfMonthsBetweenYears) );
info("No Of days : " +int2str(noOfDays));
thanks for you reply.
it is working fine.
but in below examples it gives negative values
start date(28/06/1995) and end date(14/02/2012)
Can you use abs() function?
date inputDate = str2Date(“28/06/1995”, 123);
date refDate = str2Date(“14/02/2012”, 123);
info(“noOfMonths :”+int2str(abs(noOfMonths)) + " ,NoOfYears :"+int2str(abs(noOfMonthsBetweenYears)) );
info("No Of days : " +int2str(abs(noOfDays)));
