hey guys,
does anyone know what’s the difference between inactive and past workers in the hr-module? The lists always contain the same workers. When do the lists differ?
hey guys,
The inactive functionality in AX refers to process of deactivating a current position of an active employee. Thus the position will no longer be active and the position duration will not be available , Thus to hire a new worker in the respective position or to reassign the position you need to update the duration of the position with a new time-frame. The inactive positions will be updated in “Inactive Positions form” The Past worker functionality in AX refers to the process of terminating the employee from the organization, thus you need to lay off an employee, Once the employee is terminated the employee will be shifted from " Current active Employee form" to “Past worker Form”
