Hi friends
what is the difference between “show all corrected layers” and ‘show all from corrected layer’ .
In tools---->options----Development tab----->Application object layer.
In my testing i found the two as the same.
Hi friends
Hai Chandu,
Hi naresh,
Got the answer.thanks for replay/
Let us take eg: bus and usr
Show corrected layer : Modifications that are done in current layer(‘bus’ layer) will be shown.If modifications are done in highest layer( like ‘usr’ layer) then bus layer will be disappeared and ‘usr’ layer will be shown.If you open your instance in either ‘bus’ or ‘usr’ you can see only ‘usr’
Show all from corrcted layers: Same as above but both ‘bus’ and ‘usr’ layer will be shown.
thanks.
