hello everyone
i want to created dialogbox with radio button …
kindly reply possible solution.
Thanking You.
hello everyone
Thanking You.
Use an enum or EDT with Style property set to Radio button.
Martin I created my EDT with style as checkbox but i dnt know how to use that in dialog box could u explain me???
You’ll find a bunch of examples if you look in AX or even on Internet - don’t be lazy. At first check this: Creating a Dialog. (If you have AX2012, use extendedTypeStr() or enumStr() instead of typeId() in addField().)
Hi Manimaran,
Use the below code to generate a simple dialog with check box.
Dialog dlg;
DialogField dlgField;
DialogGroup dlgGrp;
dlg = new Dialog(“Simple Dialog”);
dlgGrp = dlg.addGroup(“Test”);
dlgField = dlg.addField(TypeID(NoYesId), “Selection”);
dlg.run();
Try this code in Job.
Hi Pratham,
Use the below code to create a simple dialog with radio button. But before writing this code in JOB, you have to create a base enum with 2 elements and set the style property to “Radio Button”.
Consider I have created a BaseEnum named “Result” with style property set to “Radio Button”.
Try this code in a JOB.
Dialog dlg = new Dialog();
FormRadioControl formControl;
dlgField = dlg.addField(typeid(RadioButton));
formControl = dlgField.control();
dlg.run();
Hope it works…
Ya its working faisal Raja Thanks For ur reply…
