how to bring the current Bank account in dialog field automaticaly when generating the cheque report through path
AP>journal>paymentJournal>function>generate payments
You can get this by adding the below code to the class - VendSumForPaym.
in the main method add the code which is bold underlined…
VendSumForPaym vendSumForPaym;
boolean runDialog;
ledgerJournalTrans ledgerJournalTrans_bank;
switch (args.dataset())
case tablenum(LedgerJournalTrans) :
ledgerJournalTrans_bank = args.record();
vendSumForPaym = CustVendSumForPaym::newLedgerJournalTrans(args.record());
runDialog = vendSumForPaym.validateTransactions();
if (ledgerJournalTrans_bank.OffsetAccountType == LedgerJournalACType::Bank)
vendSumForPaym.parmBankAccountID(ledgerJournalTrans_bank.OffsetAccount);
break;
default :
throw error(Error::wrongUseOfFunction("@SYS24287"));
Thanks Kranthi Its working fine
