Hi All
how to initialize the value of the other fields if the value of the current field is changed in dialog.
i have created a dialog using class…
Nitish Kr
Hi All
Nitish Kr
Do you want to take value from dialog?? there are simple code in axapta tutorial,check them they will help you…
Good working
Hi Hülya,
I have to show the lookup on the other field if value of the current field is change…
i have 2 lookup forms which i want to show in other field in dialog on 2 different condition in current field…
when i change the value in current field accordingly the lookup will change in other field…
it is not passible using Dailog.But u can make a form into dialog and do what ever you want…
