Dialog in X++ Code
I want to create a dialog in X++ Code.
I have a lookup dialogfield where I can choose a VendorId from VendorTable. Now I have another dialogfield and I want it to display the VendorName of the selected VendorId.
How can I get the dialog to update the dialogfield and show the VendorName?
Write code as dialog.allowUpdateOnSelectCtrl(true); in dialog method
and under dialogselectcontrol() method u can automatically fill the vendore name as
Vendtable Vendtable;
Vendtable = Vendtable ::find(fieldAccount.value());
fieldName.value(Vendtable .Name);
Thnks
you can override the method “DialogSelectControl” to get the vendors name.
I still don’t understand how I can implement these methods.
Could you explain a bit more?
hi,
hope this helps u
http://parimalajyothijp.blogspot.in/2012/04/showing-value-of-one-field-value-on.html
