Dialog filter
I want to filter the values in dialog lookup…
EX:
In a report …SysQueryForm user enter the input…there he will find the looup in that look up I want Filter.
Regards
Sunil
I don’t think you can filter one field in dialog based on the other dialog fields value…
Same quedstion am also haveing?
In dialog I need to filter the value based on the another filed in the same dialog?is there any method for that?
Saju, if you have any query add it as new post. because it leads to confusion to the poster.
there you filter by rightclick on and filter as normal…just when u filte in the normal grid in the form…
Ok kranthi thanks for your guidence…
