Dialog Class
For Report i write Dialog class in that there should be dimension
Forthe dimension there is three fields for that i need only two fields country,region,product
in that i did not need product but it will come automatically how will i avoid it
Hi Selvan,
To fix your issue, you will have to get the Dimension control and remove the string you dont want to see.
In my dialog() method I have added this line,
dimension = dialog.addField(typeid(SysDimension)); // Add the SysDimension - Department, Cost Center & Purpose
Override dialogPostRun and get the control and delete the string. In my case, I want to remove Purpose string.
public void dialogPostRun(DialogRunbase dialog)
FormRun formRun;
FormComboBoxControl formComboBoxControl;
super(dialog);
formRun = dialog.formRun();
formComboBoxControl = formRun.design().controlName(dimension.name());
formComboBoxControl.delete(“Purpose”);
Hope this helps.
