I am writing code for creating a dialog box. While adding the field to dialog box by using the Dialog.AddField() method, How to specify the value instead of using any EDT(by TypeId) directly. Please let me …
First you need to add dialog field to the dialog(what type it is) - and then you can assign value to it.
DialogField dialogSiteId;
DialogRunbase dialog;
InventSiteId siteId;
dialogSiteId = dialog.addFieldValue(TypeId(InventSiteId),siteId);
dialogSiteId.value(1);
Thanks Kranthi for your reply,
Hope you have understood my requirement differently.
I want to write my code as
dialogsiteId = dialogfield.addField(xxx,“Score”);
In place of xxx , i dont have a edt xxx defined to specify as
dialogsiteId = dialogfield.addField(TypeId(xxx),“Score”);
, and my variable is score of int type. so how to specify withot typeId(), in Addfield.
finally my requirement is in my dialog box i should get a score field which accepts integer value.and value is specified by me when the dialog is run’d.
ok - then use the below code
dialogInt = dialog.addFieldValue(Types::Integer,number,“Score”);
Thanks kranthi.
its working fine…
I tried to use the same as Type::Real, Identifying th enum “types” made me difficult.
Thanks Again
is there any way to use WinAPI::browseForFolderDialog() in dialog?
