Hello,
Please I just installed Dynamics 365 and I discovered that there is no C/Side environment. How can I go to the development environment and also using AL?
Kindly advise and assist.
Best Regards
Hello,
Best Regards
Where have you been the last 3 years, if you just discovered that Business Central no longer support C/Side and C/AL code? [emoticon:b5038b8386d240d3adfaf15c98300abc]
In Business Central your development environment is Visual Studio Code. Here you need to download the AL Extension to write you AL code.
Did you find anything on Google regarding this??
I will suggest you to explore Business central up to a certain degree and then come back here with more specific question? [emoticon:c4563cd7d5574777a71c318021cbbcc8]
