Developers Toolkit - I am stuck!!!
Hi, I am using the developers toolkit and I am at the point where I want to do a merge & compare but I am getting an error in this process. Basically it is telling me that the Name field in the Field/Control table is not big enough! [:(!] My developers license does not allow me access to change the field. Any suggestions[?] Thanks
Hi, Try to find which name of field exceed 80 char, and so decrease it because you could’n touch at he field control table.
I think thats my problem, but by looking at the error message it shows a function with all its parameters as a string is too long to fit in this field. I will dig around a bit more…
what version are you using, since some of the older ones had hotfixes released for overflow errors
Version 1.03 (With Navision 3.70 objects)
