Developer toolkit crashes in secured terminal server environment
Whe’ve installed the latest developer toolkit on a Windows 2008 R2 terminal server, that has GPO security settings to prevent unwanted programm’s from being run. As an administrator I’m able to run the program, make a connection to the database and open a company. But as a user, after selecting a database and selecting OK, the programm chrashes with following error. Has anyone come across this error? Or do you know how to resolve this.
thanks for your reply.
Probleemhandtekening:
Gebeurtenisnaam van probleem: APPCRASH
Naam van de toepassing: DevTool.exe
Versie van toepassing: 3.1.0.410
Tijdstempel van toepassing: 00000000
Naam van foutmodule: ntdll.dll
Versie van foutmodule: 6.1.7601.17725
Tijdstempel van foutmodule: 4ec49b8f
Uitzonderingscode: c0000005
Uitzonderingsmarge: 0002ecaa
Versie van besturingssysteem: 6.1.7601.2.1.0.18.10
Landinstelling-id: 1043
Aanvullende informatie 1: e8ad
Aanvullende informatie 2: e8adce1c2b9e7be834b4063ac3c53863
Aanvullende informatie 3: e8ad
Aanvullende informatie 4: e8adce1c2b9e7be834b4063ac3c53863
I have not experienced exactly this issue but you could check for a few things
  • When logging is as normal user - Try to Right click on the icon on the desktop and choose “Run as Administrator”
  • Make sure that there are no other users connected to the database so theres only one user
  • Make sure that user that runs the Developertoolkit has write access to the folder where the toolkit app is installed (ZUP-file issue)
