determine actual and standard cost differences if costing method not standard
Dear All,
I am facing a problem relates to costing in navision especially to determine the difference between actual cost and planned cost when I use FIFO or other costing exclude standard. What I mean here that is my raw material used FIFO but manufactured goods use standard costing. I appreciate your answer so much. Tks a lot.
Rgds,
That is exactly the situation when applying FIFO and using Manufacturing.
You could Post Expected costs and monotor the variance - but that does not change the way that Navision functions…
Inorder to help you find/develop a ‘work around’ please tell us what you want to see and what your want to see happen.
Dear friend,
tks a lot for your reply. I consider there is a business unit in the corporate that produces some products but have FIFO costing for their raw materials and finish good but use activity based costing for their manufacturing plant. The operators of machine and other production calculation based on that costing meanwhile raw materials and finish good will use FIFO. I create item’s production BOM and mapping the process using the routing. Using item card I will calculate standard cost then, but the raw materials standard cost field after calculation is filled by system, meanwhile it is FIFO, only finish good is standard. This is the first problem. Then when I post consumption with a different cost according to FIFO (actual cost), will it affect the cost of items (WIP) and later the cost of finish good ? I wish the cost can be maintained as FIFO for raw materials and when posting output to cap. ledger entry, it is according to standard cost, I mean there will be recorded variance. It is job shop and repetitive production type. Do you think it is possible to do that in the such company ?
Rgds,
