Detailed Tial Balance Error
When trying the run the Detailed Trial Balance on RTC, I get the following error message “The Hidden expression used in table “Table1” returned a data type that is not valid”. However, if I run this same report in Classis Client, it generates without issues. Has anyone else encountered this problem? If so, what was the resolution? Thanks
Which version and have you done any modifications in report?
