Nw when I read your code I understand. That is, what’s coming in from oneventTickPrice.
There are only 3 values from that method.
The other fields, like spread, status, price 5 min ago, price 10 min ago, triggerprice, stopprice etc etc just to name a few, which are all calculated by me, has to be written too.
Should that mean that everywhere I want to write an own calculated value, I have to call select forupdate temptable etc?
But also everywhere I want to read a value, I have to write a select statement?
That would make the code harder to read, that’s why I have put it in the “parmMethods” (however I understand that that code was not designed for tables…)
But I mean in my method PriceCalculation:
tmpTable.Spread(_id, tmpTable.ask(_id) - tmpTable.bid(_id))
Is easier to read than doing this with 3 selects in the code?
So thats why I put those methods “on a higher level”
Besides that all the other 25 selfcalculated fields has only to do with 1 id and independent of the tickType.
And specially that I don’t understand why I would spread it over more records per _id.
I did mean that per id a record is hold, like custtable etc. I know primary keys of n fields.
Now the above looks like I think I know it better than you Martin. Well…for sure that’s not the case. Compared to you I’m a starter [emoticon:c4563cd7d5574777a71c318021cbbcc8]
For sure it’s good to code as clean as possible to avoid bugs etc, but it looks like we have a different view of the tabledesign in this case.
Wait…now I’m cracking my head around it:
Is it that you think of more tables?
1 with “basic data” and a lot of (myself calculated) fields , and 1 joined with this maintable, where you put the price records per _id and _ticktype as in your example?
