Description of value
Hi
I tried to update report (5605 Fixed Asset - Book Value 01) in object designer when I tried to add FA location Name
the name of location related to the fixed asset number 1 appeared beside the fixed asset number 2 and so on
although i did the relation with FA location Table
You are probably retrieving the Location Name value after the data has already been displayed. Try moving your code. Generally you retrieve data from related tables inside the OnAfterGetRecord trigger.
