Description field in GenerealJournalAmountEntry (ax2012 r3)
HI all,
when posting through JV , i get Description in GenerealJournalAmountEntry table. But when i do posting through Free txt
the Description field in GenerealJournalAmountEntry table does not populated where all other fields are populated.
In which class other fields are get populated?
During posting the description is added in CustInvoiceLine which is copied to Description field in GenerealJournalAmountEntry .
What is the relation between CustInvoiceLine & GenerealJournalAmountEntry ?
Hi Manish,
Are you referring to table “GeneralJournalAccountEntry”, because AX doesn’t have table “GeneralJournalAmounttEntry”.
Yes Nash,
It is Generaljournalaccountentry.
Can you please suggest me any solution.
You should be able to find that by debugging? Have you tried to debug?
Look at the cross references for that field to know where it being written, this will help you to understand which code to debug.
Hi Kartik,
I checked with debugging, but couldn’t find.
I am not able to find relationship between custinvoiceline anGeneraljournalamountentry table.
Please suggest.
Manish,
Did you check with cross reference as Kranthi Suggested ? I hope you know about cross reference tool
Manish,
Are you using cross reference as kranthi suggested ? I hope you know about Cross reference tool
There is no direct relation between custInvoiceLine and GeneralJournalAccountEntry.
You need to find the GeneralJournalAccountEntry with voucher and transaction date.
See the white paper in the below link,
https://technet.microsoft.com/en-us/library/hh292603.aspx
What have you checked with the debugging?
