Depreciation not getting calculated
Depreciation Starting Date must have a value in FA Depreciation Book: FA No.=EI0000024, Depreciation Book Code=COMPANY. It cannot be zero or empty.
Getting the above error while calculating the depreciation of fixed asset. I have tried searching this asset in FA master but it is not there.
Are you saying the asset is not found in the asset master? Have you tried to export the FA tables using a configuration package?
@Bhagesh - Every Fixed Asset requires setting the Depreciation Book and Method (i.e. Straight Line) and then you set the Starting Depreciation Date and Years/Months. Then you can calculate depreciation. Check the Fast Tab settings.
Steve
