Deploying CU7 environent to CU6 environment
Hello all,
I have to deploy from build environment to prod environment.
Then I have a quietion, the build enviromnet is CU7 but prod enviromnet is CU6.
So,I would like to know which there are some issues or not.
It’s not supported at all.
Either create a new build environment on the same version as Prod (CU6), or upgrade Prod to CU7. If you already have upgraded the application to CU7, your upgrade is almost done anyway.
Thank you Martin.[:)]
We decided to upgrade prod environment to CU7.
