I tried to deploy the SSRS report to server by right click on the AOT tree node. but i got the error information as below.
(It can work before)
i google the error and try to find out the solution, but the thing is none of them match my issue.
i deploy the SSRS and extensions on the SQL server, do the report development on another machine.
- I can ping the SQL server by NetBIOS name.(network is fine)
- I can explorer the SSRS report by IE, and also delete them.(i have the privilige and the service is accessable)
- On the SQL server there is no other service use the same port “80”. NO IIS installed.(no port clash)
- windows “Remote Registry” service is running on both side.
- the AX client is running as an administrator
do i miss anything else ?
many thanks.
