Hi Guys,
I have already done modifying an SSRS report from TEST server and the modification is now approved by the customer. So they want it to be available in PROD server.
May i know how to do it? Please help.
Looking forward to hearing from you guys.
Thanks!
AML
After moving the report into the AOS production environment, you can read the document “Deploying Customizations Across Microsoft Dynamics AX 2012 Environments“ how to do it. http://www.microsoft.com/en-us/download/details.aspx?id=26571
You should publish the report into Reporting Server Using the command “Publish-AXReport –ReportName”
