Delivery date control methods in AX 2012
Our client wants the functionality,whena BOM type item is entered in sales order,sustem should check the on hand stock,if stock is not there then it should check the child items availability & lead time to purchase/Production.
Can it be possible in AX 2012 by assigning CTP to the BOM items?
Nitin Pate
Yes in theory - where does it not work for you?
hi adam,
i have set the ctp for a bom item in default order setting.
the bom item’s stock is not there,so during sales order line entry system is not checking child level items stock as well as purchase lead times.
let me know if i am missing any setup.
You need to ensure each component is set with the correct delivery control in the default order settings (or site specific settings depending where the control is)
