If we delete any table from AOT, then can we restore It agin???
AK
AK
Hi AK,
Axapta 3 was the only version to have a recycle bin. Newer versions dont have this feature.
Not unless you have some kind of code backup (XPO or layer file)
Thanks Rajkumar and Harish…!
From AX 4.0 onwards MS integrated version control functionality in standard AX. Since then recycle bin functionality was deprecated.
Correct me if I am wrong. From memory, even recycle bin in AX 3.0 was not dependable because it is per session. In other words, if you close and open AX client, objects in recycle bin will be wiped out.
