delete/hide a row from a report under a condition
Hi
How to delete or hide the row in a report. scenario: if Value ==0 then the whole row must not appear on the report.
Please help!!!
Sinoyolo
You have 2 possible scenarios:
-Your report is populated with a fetch() method, just add a test in the sql query where your field != 0, the corresponding lines won’t be fetched
-Your do not have a fetch() method, so you can manage display in execute section: add an executeSection() method in your section with the following code :
if(your_field > 0)
super();
regards,
Thomas
Hi Thomas
Thank you for your response.
When I do this on executeSection:
if (LineAmount !=0)
super();
OR
if(LineAmount >0)
super();
my report comes up empty…no data at all, just the headings and only only one page comes up out of hundreds.
I don’t really get what is going on here, because your solution should help. confused
Thank you
Sinoyolo
try to test your values inside the executeSection() with an info() statement (info(strfmt("%1",YourDataSourceTable.YourField)):wink: then put the super() in a condition, you should test your datasource instead of a variable (lineAmount seems to be a variable in your exemple)
Hi Thomas
It worked out fine. Sorry I took long to verify, I’m scooped with too much, I’m actually overwhelmed, as an intern I never thought I’d be so under pressure.
Sinoyolo
