DEL_PBATranslateConsistOf Table
Hi Everyone,
Can somebody know, what is the use of “DEL_PBATranslateConsistOf” table in AX 2009. I want to view the data inside that table but it doesn’t allow me to view the data. The table is visible in AOT section but doesn’t exist in SQL server database tables. Please help.
Jeremy
The PBATranslateConsistOf should have existed in earlier version and deleted in AX 2009, to support the upgrade they will included in the future versions and will be prefixed with DEL. If the configuration is disabled in AX 2009 the related tables will be deleted from the SQL database(though they exist on AOT). In your case the configuration key “Keep update objects 4.1” might have been disabled in the Administration → Setup → System → Configuration → Administration
