How do I define a variable under Global C/AL Symbols?
If i’m understanding you right, you are looking at how to define a variable that appears in C/AL Symbols Menu. Pretty straight forward : From Navision Menu bar, 1.Select Tools–>Object Designer 2.Select Object in which you want to define the variable 4.Go to Design Mode and 3.Select View–>C/AL Globals and define your variable. After defining, when you select C/AL Symbols Menu, variable defined by you shall appear in the list.
Please post your request in the appropriate forum, next time. You should have posted this request in Developer Forum.
Correct Mohammad - topic moved to “Navision Developer Forum”.
