I created a report, to bring some information of purchase orders.
However, most orders have this field empty.
I put a range on the report, but I can not define what is to bring all the OC which this field is <> Null.
How can I do this?
The field is Purchline.ReqAttention.
Hugs,
Mateus Furrier
If you are working on AX 2009 reports you may add a new range for the field Purchline.ReqAttention with value as !’ ’ (not null). In case of SSRS reports, you need to modify your SQL query.
Hi Saurabh,
I tried to put it that way, however, the field is string did not accept the rule.
We use DAX2009.
Hugs,
AX doesn’t use nullable fields, therefore you actually want a filter for an empty string, not a null string.
!"" should work, if it’s really a string range field and not something else (in that case, you will have to provide more corrected information).
