In AX 2009, if I only have one site, does it mean the AX will only use Default Order settings? If I still set up some site specific settings, AX will look at that as well? Where do I set up the default site for the company account?
hi,
this is system limitation for AX 2009. you need to customize on this.
If you only have one site it is default by design, so set it against the customers and vendors and you never set it elsewhere. The default order settings are frankly irrelevant from a site perspecitve as would be the site specific. You are just looking at order modifiers setting these up.
