Default Financial Dimensions in Segmented Entry Control
Is there any possibility to get the Default Financial Dimensions in the Segmented Entry Control, as we can can see the standard
Ledger Accounts in the Segmented Entry Control. In the same way can we get the Default Financial Dimensions in the
Segmented Entry Control ??? (AX 2012 R2)
Thanks in advance
Sreekanth.
Is your question about segmented entry control or do you want initialize a ledger dimension with values from a default dimension (which doesn’t depend on which type of control, if any, you use to visualize the data)?
