I want to ask if there is a way in AX2012 to give specific ledger account default financial dimension values in all transactions related to this account.
example:
Ledger account :5200012
when I want to create general journal entry for this account , it must have the following dimension values:
Yes we can, in the Configure account structure form. Firstly select Main Account and you will find a Filter, click on it a form opens where you can define a rule for the desired ledger account. opt for second option Specify which values are allowed (the selected option must be IS, ) and the same setup is done for other dimensions…
… if you find this post helpful, Verify the Solution ,…
In Main accounts accounts form, set the field “select level of main accounts to display” to “companies” and choose a legal entity in the Companies drop down.
Then, “Financial dimensions” tab appears where you can set up the default dimensions.
