Decimal value problem in Real for AX 2009
I am working in ax 2009 .
i have changed the real property in for the cost amount edt where i put the no. of decimal points as 16,
I have a form InventAdjInventOnHand where we have a field called edit now so the field will accept 16 decimals.
In the form i click on select and select an item then it will fetch the record in the form , when i click on edit now and then click on adjustment then on amount it pops up a window where I enter vaulue like 12.45122445121
when i click on ok
then in the form it will get saved as 12.450000000000
when ever i am entering any vaulue like 12.457754454 the data is getting saved as 12.45000000000
This https://community.dynamics.com/ax/f/33/t/42031 and this https://community.dynamics.com/ax/f/33/t/28485 may be helpful.
PG
Here is a related post,
