Decimal Places on Reports
I have a field on a report with a decimal place value set to <2:2>
This means minimum of 2, maximum of 2 decimal places, doesn’t it?
I have a report and it doesn’t seem to work, it only wants to show 1 decimal place. Any ideas what to do? I need 2 places really, even if it’s a zero.
Thanks all. [:)]
Hi Nigel,
Is this a “classic” NAV report or RDLC?
I believe it’s a classic one.
Look at the decimal property of that textbox.
And make sure that the field that you want to print with two decimals actually is a decimal field and that it has not been “converted” to a text field first (I have seen this error before). Because otherwise your setting is correct, it’s the DecimalPlaces property that is used to define it.
(Amol: There is no property called Decimal on textboxes!).
Nigel, did this solve you problem?
