Is it possible to use a navision version with a newer debugger version? I think it is not possible, but I try [:D] Thank you John
Bit cryptical, but here goes. You can perform a technical upgrade, which means keeping the same application objects you now have (Tables, Forms… the whole logic) but upgrading the executable files. This is a fast procedure which takes only as long as uninstalling the old server and all the old clients and installing the new server and the new clients throughout your whole network.
