Dear all,
Am facing one issue in ax 2009 client…
while am trying to open my ax client the debugger automatically enables and it is not allowing to work on…
the issue am facing while opening my ax client
please give any solutions for this guys…
thanks in advance
Your screenshot doesn’t show any debugger. It shows a dialog telling you that a break exception occurred. It usually happen if you press Ctrl+Break to interrupt a running activity, but in your case, it seems to be caused by a bug in code. Use the debugger to find which line of code is causing it.
