I have a .net application that i am using to create the transfer order using the .net business connector.
I don’t have the source code for this .net application.
Can i activate the debugger on AX to get the logic behind the application. I want to see which class , function , methods he is using to create the transfer order.
So can i start the debugger on AOS to see what he is doing to insert the record.
