From date_________ Todate _______ and Dimension(Dropdownmenu).
When i am click on Dimension field (DropDownmenu),Suddenly the Debugger is coming with some error.I have not given any breakpoint at anywhere.Plese help me get out of this issue…
I believe this is by design, the problem is that you need a real table field of type Dimension but since you are just using a dialog field for this then you get the assertion failure, this should work as mentioned before if you just disable the debugger. As I mentioned, this is by design, the report LedgerBugdetReport also has the same problem.
However, this is not the solution(the same blogged in lot of articles).
Need to find the cause rather than skipping code or disabling break point.
BTW, we also facing same error though it seems everything fine. This may be due to Base & derived classes
reference may not updated.
Probably doing Full compile + Full CIL may fix the issue.
