DBCC CheckDB
Hi ,
Any body know what are allocation errors in SQL server … when running DBCC CHECKDB …
How can i solve the problem if i have 3 allocation errors
CHECKDB found 3 allocation errors and 0 consistency errors in database ‘testing datbase’.repair_allow_data_loss is the minimum repair level for the errors found by DBCC CHECKDB (testing database).
DBCC execution completed. If DBCC printed error messages, contact your system administrator.
The solution is to do backup from navision … where we have to wait a long time if the database is big ,
the do a new database from navision and not from sql … the restore it from navision also it will take a long time …
then when you do DBCC CHECKDB … you will not have more errors …
