DAX 2012 R3 Test Data
Good Day,
How to restore the Contoso Data in Dynamics AX 2012 R3??
Ragards.
r0bert
Hi Robert,
In earlier version we imported .dat file now it is DynamicsAX2012R3DemoData.exe.Its available in Partner source.
If we run the exe file it will extract the data.
The below image explains the extraction of data.
It contains three types of files:
  • Xml (A bcp data file that contains table data. Columns are separated by #|EOC|#. Rows are separated by #|EOR|#\n.)
  • Out (A bcp data file that contains the table metadata (column descriptions).
  • OutModel (This metadata includes all names and IDs of the table and its fields. This file also includes the element Type attribute, which stores the names and IDs of any Microsoft Dynamics AX tables, classes, or extended data types that are referenced by the table)
To import this data we need to Test Data Transfer Tool. It is available in Information Source
Link for Test Data Transfer Tool:
https://informationsource.dynamics.com//RFPServicesOnline/Rfpservicesonline.aspx?ToolDocName=Microsoft+Dynamics+AX+2012+Test+Data+Transfer+Tool+(Beta)%7cQJ4JEM76642V-8-1465
Run setup file
Click next:
Accept terms in the license Agreement
Click next
Once installation is done, we can observe folder in program files (x86),as shown in below image.
In the folder we will find one .xpo file.
Import xpo file in AX.
Once import is done, will observe one job under Jobs node as shown above image.
Run the Job, it generates one metadata.xml file in temporary file path as shown in below image.
Go to the specified path as shown in the info log.
Copy the Metaata.xml file and paste into C:\Program Files (x86)\Microsoft Dynamics AX 2012 Test Data Transfer Tool (Beta)[Lists] .Already exist overwrite it.
Go to cmd Promt:
Change the directory to Programfiles x86>> Microsoft Dynamics AX 2012 Test Data Transfer Tool (Beta)
As shown in the image
Enter Y.
It will take couple of hours… and it depends upon the respective machine.
Once finished it. Observe the demo data in AX.
