DAX 2012 R2 dimensionDefaultingControllerTable
Hello,
ok, we create a financials dimensions tab on a ax 2012 form -
lets think we have 4 dimensions - so 4 comboboxes, if i change 1 value and i want to add code which would fire after i change “Departament” dimension value, where should i put the code ?
DS DefaultDimension field Modified method doesnt fire,
Controls are generated by DimensionDefaultingController::constructInTabWithValues so i cant reach “modified” method on them
dimensionDefaultingControllerLine.dimensionLinkChangeEnumValue += eventhandler(torFinDimCheck::check);
doesnt work too
The modification of dimension attribute value triggers this method,
\Classes\DimensionDefaultingController\handleValueModified
One solution would be to implement your own class that extends the DimensionDefaultingController, where you can override the handleValueModified to implement you own logic
notifyValuesChanged method → not handleValueModified :slight_smile: but thanks :slight_smile:
